Car is a honda civic vti 1999.
was going to change the ignition switch since its faulty though by holding crank you can get it to start.
first i tried to disconnect battery(safety since starting electrical work) and I constantly hit the negative cable with my socket wrench many times even leaving the wrench connected the two for a while. It damaged battery circle part(you can see the fresh silver part). its actually worse then what you see in the pic because afterwards I did even more damage.
I tried to change switch but got confused as I wasnt sure how to disconnect one of the wires(ill probably ask a question about that later). As such didnt use the new switch and just put the original one on again.
Now car doesnt crank even if you hold the key right though it did before.
Would the damage to battery terminal cause the car to not crank? please see pic. Note that lights and electronic windows are working. enter image description here I think everything has been reconnected as before. Any idea what might have gone wrong?
Edit from duplicate post:
I found the problem. The wire comes from the one of the two end scarts of an ignition switch. It is one of two plastics which house the key-ignition cylinder lock. Originally I thought it was plastic so was trying to test\crank the car without it on however I later realized the electric part and on putting it back car did crank. Can someone tell me what the name of this part is and what its function is. I think it has something to do with an immobilizer.
    Post the Year, Make and Model of vehicle please.
    – Moab
    Jul 31, 2019 at 22:19
It is highly unlikely that you have damaged the battery.
Are there any lights that are indicating that the immobiliser is active? I think that is most likely what is causing the engine not to crank.
The sensor loop for the immobiliser is usually around the ignition switch, did you disturb it, or disconnect it?
  • i remember it was very difficult to put the cable parts of the ignition switch in, i wrestled it in.because there were wires in the way. however i dont see that anything has moved out of place. Jul 31, 2019 at 22:51
  • @JamesWilson you may not have "moved them out of place" but you may well have broken one or more...
    Aug 1, 2019 at 7:37
  • I’d also assume that one or more fuses are blown so it’s worth checking all of them (they’re right there in the picture).
    – Bob Cross
    Aug 1, 2019 at 10:10
  • HandyHowdie, is the part in the new pic the sensor loop for the immobiliser? thanks Aug 1, 2019 at 20:57
  • @JamesWilson It certainly looks like it could be.
    – HandyHowie
    Aug 1, 2019 at 21:10
