I have a 2007 Honda Odyssey that will start in neutral but not park. Any ideas and how would I fix this or what would it cost to fix? Thanks
1 Answer
That the sign of a bad park/neutral switch.Find out where it is on you car and replace it.
I pretty sure it wouldn't start in either position if the neutral safety switch was out.– Pᴀᴜʟsᴛᴇʀ2 ♦Jul 27, 2019 at 7:45
1Not true. It's actually a very common failure. The park position contacts have the most wear since they're used 99.0000 % of the time. Starting in neutral but not park is the most common symptom of park/neutral switch failure.– user9181Jul 27, 2019 at 14:22
