My rear hatch is not opening all the way. When it goes up it stops at almost the top and the it jolts back down until it closes. It acts like something is blocking it from opening all the way. Any suggestions of what might be causing this?
  • Is there anything on the struts?
    Jul 25, 2019 at 16:50
  • Is there resistance when pulling it open?
    – user4321
    Jul 26, 2019 at 9:50
  • Nothing on struts and no resistance when opening. Jul 26, 2019 at 12:30
  • I am going to try to replace the lift supports and see if that solves it. Jul 26, 2019 at 13:52
I replaced the lift rods for the hatch and it fixed the problem. Took less then 10 minutes to change them out.
  • Yay! Glad you found a fix! Welcome to Motor Vehicle Maintenance & Repair, by the way!
    – Cullub
    Aug 1, 2019 at 20:01
