I just replaced my front stabilizer bar bushings to fix a clunking noise I was getting. It solved the problem and the clunking is gone, but the replacement bushings don't seem to fit quite exactly. They are the correct aftermarket units.
The bar is centered as far as I can tell, the bushings are fully in the grooves, brackets are torqued to spec (29 ft/lb) and oriented correctly.
I've tried removing and reseating the bushings, shuffling the bar and brackets around a bit, but I just can't get these bushings to close up.
Is this a problem?
