That is the simplest way I can describe the problem. I changed into my summer tires and after that after I get past 40 kph the car starts to get very loud. Between 60 and 100 is a little quieter but not by much. Driving at 120 kph is tolerable.
It does not feel like I have unbalanced tires since the care is not shaking or jumping. I had a complete brake job since and the did nothing to change the issue. My car just drives loud. Likely unrelated but my A/C also stopped putting out cold air.
I thought maybe that I had rotated my tires incorrectly but they are not uni directional from what I can tell. I was going to rotate them again but I feel like that might be a waste of time.
Only other thing worth mentioning is that when I am turning left at higher speeds the noise almost goes away. Conversely if I am turning right it gets louder.
What is the possible cause of the noise in my 2012 Mazda 3?
  • Welcome to Motor Vehicle Maintenance & Repair! Jul 17, 2019 at 22:41
If the noise gets louder when turning in a particular direction it sounds like a wheel bearing failing. Mechanics often test wheel bearings by steering one way & then the other... basically this puts more load on a particular bearing and helps identify which bearing is failing.. Your AC may just need a re-gas or its belt tightening etc but this will need investigating further.
