I was having a problem with the AC in my 1997 Accord recently. My dealer did an evac and recharge, found a leak, and replaced the compressor. Then they said the system was over-pressurizing, so they vacuumed the system to try to remove any clogs in addition to doing another evac/recharge. They said it was a bit better after that, but the pressure is still too high, and they think there is contamination throughout the system and recommended replacing everything.
I did a search and see it's possible to flush the AC system. However, I found a video that says a flush won't work on a "modern" car because the holes in the condenser are too small. Will a flush work on a 1997 Accord?
