I have a 2005 Honda Civic. When I shift manual transmission from 4th to 3rd, the engine revs up, but the RPM gauge drops to normal. It runs normally in the other gears.
  • Welcome to Motor Vehicle Maintenance & Repair! – Pᴀᴜʟsᴛᴇʀ2 Jul 4 '19 at 1:53
  • This sounds normal- changing down a gear should make the engine rev higher as the synchromesh comes into play when you raise the clutch pedal. – Rory Alsop Jul 5 '19 at 13:45
