My 09 Hundai Elantra have an intermittent starting problem after a few cranks and a few minutes wait it eventually starts .appears to be worst when the engine is hot. On going problem for the past two years.
  • What has the mechanic at your local service shop said about it when you put it in for service? – Rory Alsop Jun 26 at 16:21
  • Are there any check engine codes? I would start by verifying the intake air temperature and coolant temperature sensor readings make sense by monitoring those PIDs with a decent scan tool. – SteveRacer Jun 27 at 2:22
