This is from a Mk1 VW Golf and is the transmission side engine mount.
I've remove the bracket, but the mount is stuck within it. I've soaked it in WD40 and whacked it a few times with the hammer with no luck.
Would anyone know of any trick to remove it?
Pictures below of old mount in bracket next to new mount.
The best way is to use an hydraulic press.
Failing that, a long bolt or threaded rod, some nuts and a couple of sockets can work.
The final solution is to cut it to pieces with a hacksaw...
