the small brake line burst on the rear of our 2006 Kia Spectra , I just replaced the line, once it is together ,do I need to bleed the other side.
  • Welcome to Motor Vehicle Maintenance & Repair! – Pᴀᴜʟsᴛᴇʀ2 Jun 22 '19 at 4:01
  • There will be a specific order, usually farthest first, nearest last, but do check. – Solar Mike Jun 22 '19 at 4:56
  • You need to bleed at all four corners, starting from the corner furthest away hydraulically. – Huesmann Jun 24 '19 at 13:52
Once it's together, you need to bleed the entire system, as air could have entered and affect the braking ability of the vehicle. Since it's a 2006, if you're like most people, the brake fluid has never been changed in it anyway. Doing a complete flush and bleeding at all four is not going to hurt anything. Get yourself a quart of DOT4 and have at it.
