engine gone in my 2002 rav 4, 2L, diesel, but can i replace it with an avensis, corolla 2L diesel or other toyota? obviously keeping my original turbo, starter etc.
mark
Sign up to join this communityThe diesel engine in the XA20 RAV4 is the 1CD-FTV (marketed as "2.0 D-4D") - the same basic block was used in the E120 Corolla (exact model years depend on your location - it started in Japan in 2000 but came later to some markets IIRC) and both are built on the same basic platform - Toyota's "MC" platform so that makes it reasonably likely that you can do such a swap.
The Avensis used the 1CD-FTV as well (until '09) in some of the cars - however some of the second generation Avensis cars had the 1AD-FTV instead. So it would be advisable to check carefully! I think they started using that ~2005 so cars before that should be the right engine.
2nd generation (03-09) Avensis cars are also built on the MC platform.
I must stress that this isn't a swap I've seen done personally so I don't know for sure that it's doable - would have to check part numbers for that and without the frame numbers of the recipient and donor that's a needle in a stack of needles.
