I recently replaced the clutch on my 1995 VW T4 2.5D and all works well as far as the clutch is concerned but to remove the clutch I had to drop the engine and to do this one part that I had to remove was the gear shift linkage so I replaced all the gear shift bushes while I had it out to make the gear shift smother but on refitting everything I can not get the linkage to operate correctly, I can see how to correct the length by putting a pin in the selector so it remains in the natural plain and adjusting under the bottom of the gearstick but my question is how do you set up the cross plain so as the selector knows if it is going into 1st/2nd or 5th
