A couple of days ago I went over to a friend who owns an older KTM motorcycle and as I was having a look on his motor I noticed a component on his carburetor which looked like something electronic but had no cables attached to it. It is similar to the black component on this image.
What is this component?
  • Without a photo of the actual carby we couldn't say for sure. Sounds like @Solar Mike is probably right though.
    – H. Daun
    Jun 13 '19 at 7:52
That would iirc be a temperature controlled choke unit, so if it is warm enough then the choke is off.
Operated by a temperature-sensitive coiled spring.
  • i have tried to google it with "motorcycle temperature controlled choke unit" term and some variations but i cannot find much. Most of the components and images don't look the same. Probably i will take my friends carb apart to clarify this. hehehe...
    – kokobill
    Jun 13 '19 at 8:13
