2009 Scion XD, 110K miles.
I replaced my front rotors and pads with the Raybestos brake kit found on Rock Auto.com. Since I live in the rust belt, and my current rotors rusted apart before the pads burned down, I opted for the coated rotors! Anyway, I'm over 50 and have been doing my own brake jobs since 16 and don't recall the issue of pads riding on my rotors making a slight noise.
I hear it with my windows down, noise bouncing back off the curb or parked cars. It's not pressure, it's not slowing down the car. My car is not pulling when braking. I used silicone to lube the sliders. Used a wire brush to clean the calipers and brush off rust at the contact points where rotor meets the hub assembly and applied anti seize. Used the new clips with the brake kit and the pads came with shims.
It seems the pads are touching the rotors just gliding down the road making that metal noise and it's driving me nuts. Not super loud; I'm just not used to it. I took the brakes apart and I'm not happy and can't find anything wrong! Should I just wait to see if after some pad wear it goes away?
  • edit above, my is Not pulling. Brakes work great and don't squeal.
    – Ohiorain
    Jun 10, 2019 at 14:54
  • Welcome to Motor Vehicle Maintenance & Repair! Seems like you're probably more experienced than I am with brakes, but I would probably wait to see if it goes away after a bit. I have heard of this happening if you get tougher brake pads (some really heavy duty ones might take a long time to break in), but I wouldn't expect that for a Scion.
    – Cullub
    Jun 10, 2019 at 15:35
  • Also, you can edit your post by clicking the edit button to the bottom left of the post. Feel free to use that to add or change any information to make it more clear! I've taken the chance to edit that into your post for now.
    – Cullub
    Jun 10, 2019 at 15:39
You've mentioned several potential issues in terms of making sure the brake hardware was cleaned and lubed properly, so we can rule those out. In rusty environments it's common for the caliper slide pins to get sticky, causing a brake pad to drag on the rotor, which can make noise (and wear the pad quickly) even if it's not enough drag to actually cause you to feel the car pulling to that side. You said you cleaned and lubed the pins, so we can probably assume that's not the case. Anyways, it's usually obvious when this is happening as the pins will be hard to move by hand and/or you'll see uneven wear in the old pads.
However, it still might be worth a few minutes to take the wheels back off and make sure things look OK. Most cars (including yours) have a thin stamped sheet steel shield behind the brake rotor. It's flimsy and easy to bend - sometimes when it gets bent, it'll touch the edge of the rotor and make a metal-on-metal noise like you're hearing. When you're doing brake work, all it takes is an errant tool smacking that shield or you grabbing it unintentionally while working to bend it enough to cause contact with the rotor. Sometimes it'll wear itself away in a few hundred miles and stop the noise, but it's easy to check and easy to fix (you can straighten the shield by hand in most cases).
And of course, taking the wheel off will let you check that you didn't make any silly mistakes. I once helped a friend diagnose brake noise after he'd replaced his pads, it turned out he hadn't tightened one of the caliper bolts properly and it had backed out to the point that it was rubbing on the inside of the wheel. Luckily we caught it quickly.
  • I did the brake job Sat June 1st and took the brakes apart yesterday June 9th to see what the hell and why. I don't hear too much noise out of the driver side, hear more on the passenger side with the window down. Dust shields aren't touching the rotor, that would be super annoying loud. According to the manufacturer, the Raybestos pads are a cross between semi metallic and ceramic so they have both wear properties. Haven't driven the car yet today, I'll let them burn down and seat a little bit and report any more noise issues.
    – Ohiorain
    Jun 10, 2019 at 18:54
  • I'm a complete idiot, waving my hand in air. Took my right front wheel off today and got under there and spun my rotor and it was the dust shield touching the rotor driving me nuts. Noise when turning gave it away, the outer tie rod end can push the dust shield when turning. Bent it back with a big long screw driver and the noise is completely gone. I knew it couldn't have been the pads hanging up. Thanks for pointing out the obvious and keep on keepin' on.
    – Ohiorain
    Jun 16, 2019 at 19:50
  • Glad you found it. I've seen many cases where the dust shield is causing the noise!
    – dwizum
    Jun 17, 2019 at 12:34
