Can I put a 2002 honda ignition switch into a 2001 honda civic? Would it work and fit? The original ignition switch is a little bigger and has more wires than that of the 2002.
  • Is the replacement switch also from a Civic? '01 and '02 cars are both 7th gen civics so I would have expected it to be the same. The fact that it's clearly not suggests it might not be from a donor civic. I can't see you being able to bodge a different switch in effectively. Commented May 31, 2019 at 9:45
  • If you check out all the functions of both switches then get the wires in the correct positions you might then be left with any physical differences.
    Commented May 31, 2019 at 9:48
  • Motosubatsu- yes, I'm having trouble with my 01 civic have to turn key really hard to start up. Looking to see if I can put an 02 civic ignition in. Commented May 31, 2019 at 15:12
