today my car had the following problem: I was driving with about 80 km/h (ca. 50 mph) when suddenly my Motor didn't react to the gas-penal anymore and I wasn't able to accelerate. The tachometer and the speedometer dropped to zero, while I was still driving. The kilometer display wasn't showing anything anymore. Additional to that all lights showed up.
image of the tachometer
The engine didn't shut down and was still running on idle (even uphill in the second gear). After a short time, the error disappeared again. But it kept coming back regularly.
The error comes together with a bundle of error-logs which are:
Three of them relate to signals/sensors. Therefore, I guess that it's an electrical error. But I have no clue what could be causing it.
The Car is a Ford Focus Tunier 1.6 tcdi diesel 109 PS constructed in 2006 and it has about 156.000 km / 97000 miles
    The error codes make sense, but what does "no longer accepts gas" mean? If it's idling, then it's using gas...
    – Rory Alsop
    Commented May 29, 2019 at 22:40
  • Thank you for your Feedback :) The engine didn't react to the gas-pedal anymore Commented May 30, 2019 at 9:16
I had similar problem on Hilux where rev counter dropped and battery and auto transmission temp level lit up whilst driving. Took battery in to check - it was flat and after a recharge, tested good. Took alternator off and got it tested - was also fine. Put it all back together and had it tested - still fine. Only happened intermittently and when vehicle was hot, i.e. highway driving. It was a high resistance corroded connection on the battery terminal. One connector was slightly concave. Took a file and filed it clean and flat and error was fixed.
Hope it helps
I had a Rabbit GTI that did that. It was the Hall effect sensor in the distributor. The engine would flatline. Very sporadically. I had a 94 Audi 90 that would do that, but I lost every light in/on the car. Always in a blizzard. I loved those cars. Moving from VW to Audi was an adju$tment. The quattro with 5-sped diff lock makes me want to make a pot of soup to capture my tears.
