Last night, the check engine light went on on my 2006 Toyota Tacoma with 152K miles. When I got home, I plugged in my OBDII code reader and got
Does this mean I just need to replace one of my camshaft position sensors because they expired due to regular wear and tear (the truck is no spring chicken) or should I diagnose for a deeper root cause? Does it make sense to just order a replacement sensor and see if that will shut the check engine light? Should I just replace both sensors since one expiring might be a good indicator the other won't last too much longer?
You have at least two of those sensors, right? So, swap them, and when the error moves with them, it's the sensor, otherwise cabeling / ECU.
About replacing both sensors:
For most motors, the camshaft sensor is not essential. Finally, a 4stroke motor needs two revolutions for a complete cycle, and while the crankshaft sensor gives precise information about the angle of the crankshaft, it doesn't know if it's the first or second revolution. This information is taken from the camshaft sensor during the first revolution when starting the motor. Without that sensor, the motor has to find that out by other means, which is a little more difficult. As consequence, starting the motor is a bit harder, and misfires might occur, but once the motor is running, crankshaft sensor information is sufficient.
The camshaft sensor might be more important for motors with variable camshaft timing.
So, the sensor is not THAT important, and usually quite easy to replace. Replacing just one is fine. On the other side, they are not expensive, replacing both is not a big deal.
I would check the wires and connector before spending too much money.
Have you got a friendly garage / mechanic who might have a spare to "test" with?
Also, if it is the sensor then check out buying a quality one if the rest of the vehicle is good...
  • The sensor is not too expensive, they range between $20 and 50
    – amphibient
    May 28, 2019 at 16:48
