I recently bought a 2007 R6S I was wondering if there is a way to lower the front frame so there is a greater separation between the handlebars and the plastic. When I go for a very tight turn the handlebar will hit the plastic and I can't fit my hand on it. Thank you
  • change the bars or change the angle of the bar..
    May 28, 2019 at 10:52
  • @solar-mike how would I go about doing that?
    – Mavese
    May 28, 2019 at 11:06
  • The handlebar tilt may be adjustable @Mavese, in which case you could rotate it forward for more clearance.
    – GdD
    May 28, 2019 at 11:49
