-1
I have a 2003 Yaris. In 2012 I changed the headlights by buying them online, they work perfectly until today, but the electrical input that powers the positioning motor is diverged from the cable I have in the car. You know if there are adapters, I would like to solve this little thing.
My Yaris is Italian and maybe the Japanese headlights.
If the headlights are from a different year, then the connectors got changed.
So, find the matching connectors and then make the adjustments to connect the wires appropriately.
  • I'm looking for a connector, an adapter or the headlight connector so as to rewire – BOES May 27 '19 at 16:28
  • I'll re-state : "So, find the matching connectors and then make the adjustments to connect the wires appropriately."... – Solar Mike May 27 '19 at 17:09
  • ! Even if you repeat your answer, go around my question, don't answer. – BOES May 28 '19 at 7:05
  • @BOES As a trained vehicle electrician, I do have other suggestions, but following your advice I won't go there. – Solar Mike May 28 '19 at 7:14
  • ! Thank you very much, you saved me time – BOES May 28 '19 at 7:40
