i was driving down the hiway and a trash can flew off bk of a guys truck like a 12 gallon kitchen on, i ran over it and drug it, i exited off and it came out, i then got bk on the hiway and as i was getting bk on, my car cut off with all the engine light on and thermostat light etc, when i turned the key it woul activate car but would not crank, i went to check it today and now it wont let the key turn at all, as if its locked up, I did turn the tire, (wheel) and it still didnt crank, also it wont let me switch gears and the brakes are even tight as ever
    This needs to be put on a ramp and damage inspected - there could be many things causing the issue. Running over a trash can is not usually a good thing., – Solar Mike May 26 '19 at 8:53
  • Welcome to Motor Vehicle Maintenance & Repair! Agreeing with @SolarMike here ... this needs some rack time and extensive diagnostics. – Pᴀᴜʟsᴛᴇʀ2 May 26 '19 at 13:04
