I conducted a compression test on 2004 Acura TSX with over 280,000 miles. Test results from cyl 1-4 are 180, 180, 182, 182. What are the normal readings for this model car.
  • Those compression values are not the problem. Something else is. Radiator, water pump, leals, seal... – Solar Mike May 24 at 3:39
