2007 Yamaha V Star 650. The battery is not holding a charge. I've had the battery tested by the dealer and it is good. The charging system is working: 12 VDC with ignition off and 14 VDC with engine running. The only thing I've found is the fuse labeled "ignitor" is hot with the ignition off and the other fuses are cold. Is this normal?
