I drive a 2004 Honda Civic ex coupe manual with ABS, engine code D17A2 (SOHC, Vtec)
I was driving my car and slowly revved up to 7krpm (smart, I realize) and suddenly my car lost power until 3500rpm and had a check engine light. It still drove, just not at high rpm. I went to the autoparts store, checked the code, and after googling I concluded it was the camshaft position sensor, although I don't recall exactly what that code was. I bought the sensor for $60, hoping I was paying for a quality part. I replaced the sensor, but my engine light was still on. However, while I drove back to the auto parts store, I took my car up to 5k rpm with no signs of limp mode. I checked the code with the store's OBDII, and this time it said:
P0340 ENG camshaft position sensor A circuit CURRENT
P0340 Mod $11 Camshaft position sensor A circuit (Bank 1 or single sensor) CONFIRMED
Any ideas what I should try next? I thought for sure this code was asking me to replace the sensor.
Thanks for reading
Edit: While my new OBDII thing was still in the mail, my engine light turned itself off after driving a bit. I assume the code just needed clearing
    I'm not sure there is a problem. Sometimes check engine lights and codes persist after the problem is fixed and you have to clear them. I suggest you clear the codes and check engine light and see if the messages come back.
    – GdD
    May 22, 2019 at 7:17
  • Thank you, I haven't tried clearing the code yet, I didn't actually know I needed to do that. I'll update when I get a chance to test it out
    – TylerIn
    May 22, 2019 at 17:55
