I've got a 2 stroke 1 cylinder engine and its ignition system doesn't seem to work. I'm having problems with my magneto ignition system and I need help connecting everything up. I think I've connected everything right, but it still doesn't work. Am I missing another part like another coil? Should i replace it all or could you guide me how to fix it?
Edit (a little more info): It's an old soviet engine from a moped. I got it from my grandpa and i have never seen it work. I have tested the spark plug in a different engine, it works. I have tested for the spark (taking out the spark plug, touching the thread to the heatsink and trying to start it) it does not work. I have tried connecting a multimeter to the coil and i've gotten 1-3VAC. The carburator works flawlessly, the only problem i found was the spark.
Edit 2: I have tried to mostly rewire it all, I have replaced the capacitors to 2x 0.5uF capacitors wired in series. Tried to crank the engine and no dice, didn't produce a spark. The HV coil(the one that connects to the spark plug) when measuring to ground has a huge resistance of ~5mOhm while the other coil (LV i think, but not sure, the one that connects to the switch) has ~0.5Ohm. Are the coils wired up the wrong way or are they dead? (Sorry for a little sloppy soldering job in the new picture)
