I bought a 2001 Yamaha roadmaster silverado 1600 yesterday. At the guys house it fired up fine. I went back a couple of hours later and bought it. I fired it up and drove it about 30 miles home. Everything seemed fine. After I was home a couple of hours I was going to go for a ride and went to start it... nothing! No electrical power. No lights, no gauges, no nothing. I am not sure what is wrong. I haven’t been able to locate the electrical fuse box yet. Do any of you have an idea what could be wrong or where the fuse panel may be? Thanks
It could be a loose connection on a battery terminal, check to make sure those are tight before you look at anything else. – GdD May 20 '19 at 10:53
Did you leave the lights on? All too easy on a new ride... Check the battery voltage. – Solar Mike May 20 '19 at 10:59
I did. It is tight. And the battery is charged and good. – user49137 May 20 '19 at 10:59
1I figured it out. Starter relay. I replaced it and it started for about two seconds and stopped. Now it will turn over but will not start again. Ugh!!!! – user49137 May 21 '19 at 10:43
1You could add what happened to your question, OR, you could even answer this question yourself and make a new question :-). We love having clear Questions and Answers in the end, even if things get started in Comments. – Mike M May 27 '19 at 4:23
Got it figured out. New starter relay failed. Replaced it and back in the road! Thanks for all of your input!!
