I have an 02 mini one and the fan stays on when switching off. Is this normal ? And where do I top up the water please ? Thank you in advance x
Assuming you mean the radiator fan under the hood - these fans often run after a car is shut off so you're probably OK.
Also, see the red circle attached for a typical location for the coolant reservoir for a Mini One.
I highly recommend you refer to your owner's manual.
  • They run according to temperature , regardless of the ignition switch. May 19, 2019 at 0:38
  • While you are correct about location for coolant reservoir, I'd be careful answering that without knowing what water the OP wants topped up...
    – Rory Alsop
    May 19, 2019 at 19:57
