I am having problems with Astra h 1.9 88kw 2006, it's constantly going in limp mode during driving, once I put it on diagnostics it's saying gas pedal, I change it and still have a problem, can anybody help.
  • I changed the pedal 4 times in 2 years, and it only solved the problem temporarily, now even after changing it the next day it started giving me greef – Marko May 12 '19 at 15:57
  • Have you checked the wiring to the gas pedal? – Solar Mike May 12 '19 at 16:06
  • You mean from the pedal to the computer, that will be next step, it is very strange how it happenes it can come on 50 times in 1 hour and then nothing for few days as if I have Gremlins in the car – Marko May 12 '19 at 16:09
  • What is the code you get from the reader - usually more than "gas pedal". And when you have to fit 4 pedals it does tend to point to something else as the issue. – Solar Mike May 12 '19 at 16:11
  • I'm wondering if there's a grounding issue to the pedal, which when it's changed out it regains continuity, then over time, loses it again. – Pᴀᴜʟsᴛᴇʀ2 May 12 '19 at 16:12
