The sealed transmission on my Dodge 2010 Caliber seems to be slipping when I accelerate or try to accelerate up a hill. Can this be adjusted so it no longer slips or is a new transmission required.
  • Welcome to Motor Vehicle Maintenance & Repair! Not sure if you can check the fluid on your transmission? If so, you probably want to. As far as adjustments, making sure you have the right amount of fluid is usually about the only thing you can do for an automatic transmission (without pulling things apart). – Pᴀᴜʟsᴛᴇʀ2 May 12 at 1:51
