2006 Cadillac DTS 4.6L Northstar engine no crank no start fuel pump also does not come on check relays and fuses everything else works
  • Check for loose battery cables. – mike65535 May 9 '19 at 15:40
  • Welcome to Motor Vehicle Maintenance & Repair! You sure this isn't a security thing? – Pᴀᴜʟsᴛᴇʀ2 May 9 '19 at 20:44
  • That sounds similar to the symptoms produced by a faulty neutral safety switch, although in my experience the fuel pump still runs when the neutral safety switch is engaged. – the_storyteller May 9 '19 at 20:47
