I have a very gently used Craftsman leaf blower with about a 27cc 2-stroke engine. It never ran all that great, mostly it would start up fine then run for about 4 minutes until it started to slowly bog down then die. I would generally have to let it cool down before it would start up again.
I got frustrated with it so I got a tool to adjust the carb and it runs fine when the throttle is closed however as soon as I open the throttle it dies immediately. I thought the carb might need to be cleaned from sitting for a while so I took it apart however the fuel lines were practically fused to the brass fittings on the carb body. I wrestled with it using pliers however I had ended up pulling one of the brass fittings from the body of the carb.
It doesn't seem to have a threaded end, and I can't see any damage inside the hole. I don't quite understand what holds this in place and am not certain that this part is meant to be removable. It seems to hold in place somewhat when I push it back in but since I am unsure if I damaged the thing I am wondering if it might be a source of air to leak in.
Furthermore the brass fitting that came out has teeth marks on it from when i was gripping with the pliers and I am concerned that the fuel line may not form an air tight seal when I replace it.
Did I irreparably damage the carb on this engine? Should I just buy a new carb?
    In my experience, the brass hose connections are just press fit into the carburetors. If you can press them back in and they stay, you should be good to go. Maybe give them a light tap with a hammer to make sure they won't fall back out. The teeth marks could cause leaking if they're bad enough. If you're worried about them, smooth them down with a file or sand paper. Other than that, if the carb works, it's probably fine. – the_storyteller May 9 at 14:19
