on our 1982 Ford F100 Pickup, Never seen this one before... So Whatin the world can make a motor increase acceleration , instead of decreased acceleration when i removed a spark plug wire upon testing ?
  • Presumably you mean engine speed, not acceleration? – HandyHowie May 6 '19 at 16:08
  • Does the engine have an electronically controlled idle speed control valve? – HandyHowie May 6 '19 at 16:10
  • @handyhowie on a 1982 pickup I'd be amazed if it had electronic anything - even spark plugs were steam powered back then – Caius Jard May 6 '19 at 17:51
  • @CaiusJard My 1985 Ford Granada 2.8 had EFI, but maybe 1982 is a bit early. – HandyHowie May 6 '19 at 18:13
  • First fuel injection was on a production car in 1955 Mercedes... But on Fix Or Repair Daily - just a bit later... – Solar Mike May 6 '19 at 18:19
Not sure which engine you have, but all are carb as far as I can tell.
Most have either a mechanical (vaccuum) or electronic altitude/idle speed throttle compensation system. It stands to reason that this system would compensate for the drop in idle speed due to disabling one cylinder.
| improve this answer | |
  • I meant to ask what makes the motor idle ( higher ) instead of idle dropping when testing firing. Never saw this happen before. When I touch the top of plugs wires with tester the engine idle drops as should except for one plug , when I touch it with tester the stupid engine idles real high, I don't get it. – Charles Lewis May 7 '19 at 15:05
  • My motor is a 302, – Charles Lewis May 7 '19 at 15:07
  • 1982 Ford F 100, – Charles Lewis May 7 '19 at 15:08
  • Not sure what kind of tester you have - mine measures the electromagnetic field with induction in a non-contact proble and calculates estimated spark voltage - and at no time does it affect idle speed, on any engine or ignition system - distributor, COP, or otherwise. – SteveRacer May 9 '19 at 3:40
