Anybody figured out the mysterious reason behind the sudden overheat of the petrol v6 2.5L engine 2003 Kia Carnival
Coolant level is good. The radiator is good. the fan also is working No coolant leaking. There are Hoses are pressured boiling water in the Coolant reservoir I think because of the boiling steam that comes from the radiator. water bubbles in the radiator when I try to add water when it cools down. How to check for the thermostat and water pump is or not without removing the engine.
