Whenever I hot the gas or the brake, I hear a clicking and popping sound on the front right side.
I just put in w new CV axle and control arm ball joint. The sound happens during abrupt momentum change. Is it the wheel bearing? The tie rod ball joint? The new ball joint had a grease fitting, can using the wrong grease cause this?
