-2
What is meant by the term 'Measuring Points' when used in reference to the manufacturing of electric Formula Racing car. I googled and somehow got the sense that measuring points are certain terminals available from any electrical equipment to check whether its working or not by passing some voltage across these points. I know this is insanely raw or may be extremely wrong.
What does the term Measuring Points exactly mean? How to understand these points in terms of Tractive System of an Electric Formula vehicle?
I also found (EV 7.1.9) the use of these points present on the charger of an EV accumulator.
"Measuring points" can be many things:
  1. defined points on a chassis to check dimensions
  2. defined points or pins provided on a circuit for measurement of voltages etc
So, unless we know what points exactly you refer to this has many answers.
| improve this answer | |
  • Oops! I read too quickly. My apologies. – BillDOe May 2 '19 at 19:40
  • @BillDOe been there, done exactly the same, no problem :) – Solar Mike May 2 '19 at 19:43
