It has strong battery still. The horn is loud and I have all the lights. It would just click but there's no juice nor rev. What could be wrong?
  • solenoid failed, starter failed or bad battery. – Solar Mike May 1 '19 at 5:15
  • loose or corroded connection? – fred_dot_u May 1 '19 at 10:27
  • Thanks! You're right. The connection has some corrosion. I didn't know it was that simple. – Felipe Gene Dela Cruz May 2 '19 at 6:05
  • spray contacts with contact cleaner. The solenoid/actuator corrosion possibly. – Eric Punzalan Aug 14 at 23:38
