2011 Nissan Xtrail, 2L diesel, 160.000 km.
I noticed that while driving, coolant level drops below minimum mark. If i let the engine cool down, level rises to the same mark, almost to max.
What could.it be?
Thanks
    What you are describing is the exact opposite of how this should work. Automotive cooling systems are pretty simple. When water/coolant heats up it expands. The opposite happens when it cools. Exorcist, perhaps?
    – Tim Nevins
    Apr 30 '19 at 13:33
  • @TimNevins I don't know... Thinking air bubbles in the system
    – eonootz
    Apr 30 '19 at 14:50
  • Are there any problems with it overheating? Jul 4 '19 at 17:32
  • @Pᴀᴜʟsᴛᴇʀ2 Well, I think that the coolant from the overflow tank was going in an electric turbo cooler pump wich runs after turning the engine off. But i do have a new question open on a possible overheat problem with this car, maybe related...: mechanics.stackexchange.com/questions/68630/possible-overheat
    – eonootz
    Jul 4 '19 at 17:40
  • The reason if I asked if there was any overheating issues is, if there isn't any ... don't worry about it. It is probably running as designed. Jul 4 '19 at 17:49
