SOLVED
Any help appreciated!!
Both head lights are working as normal when on low beam. The moment I switch to high beam the left headlight goes to full and the right lamp goes out entirely. I've swapped the bulbs and the issue remains with the right head lamp.
I have driving lights attached to the right lamp and these no longer work either.
Many thanks in advance for any help,
Ben
  • Check all the wires / connections on the right hand headlight.
    Apr 26, 2019 at 8:31
  • I've checked all the wires and they're all intact and working as far as I can tell. Could it be a circuit breaker or fuse or something?
    – Ben
    Apr 26, 2019 at 8:35
  • Could be many things, check from either end for supply, broken wires, blown fuse etc But be logical and don't jump about - that's how you miss something.
    Apr 26, 2019 at 8:36
  • Main fuse was fine but fuse for individual light under the steering wheel had blown. Thanks for your help!
    – Ben
    Apr 26, 2019 at 9:43
  • Instead of editing your question with "solved" write your own answer with the information, then when you can, select it with the check mark to close the question ok n and actually let people know that way there is an answer which worked. That's how Stack Exchange works! Apr 26, 2019 at 19:25
I would check all the wires that connect right headlight, then if there is nothing wrong, maybe see a electrical mechanic...
  • I've checked them as far as I can and they seem to be working. Could it be a circuit breaker or fuse?
    – Ben
  • Maybe, check them too.
    – Eziooh
    Apr 26, 2019 at 8:39
  • It was an individual fuse under the steering wheel! Thanks for your help
    – Ben
  • @Ben, you can answer your own question below!
    – Bob Cross
    May 26, 2019 at 13:38
