The car is a white Toyota Camry 2012.
As you can see there are many tiny black dots on the roof. I can't remove them by scratching by hand or with a high water pressure cleaner.
What caused these dots? What can I do to remove them?
Sign up to join this communityThe car is a white Toyota Camry 2012.
Looks like tree sap indeed.
The best way to remove it is to use a clay bar after a good pre clean without putting too much pressure on the paint.
The cause can be one of many possibilities:
fly spots
tree sap
or worse paint overspray
The first two should come off - good cleaner / polish and lots of work, but the paint may mean that you need a re-spray at the worst - there may be a professional treatment that could do it. So go and see a good paintshop and see what they say.
Looks like tar spots to me - unusual to have that many on the roof but not impossible.
Try a dedicated tar remover - Autoglym do a good one (called "Intensive Tar Remover" IIRC) that should have a good chance, it also works well for tree sap (which is another likely culprit).
They are artillery fungus caused from parking near wood mulch. Read up on it. Very interesting. Very hard to remove. You must do one at a time. Ugh.
