2010 XF petrol 3.0 P171 and P174 and timing issue
For the last few months I’ve had both codes, so the time has come to resolve it, so far no joy, what have I done so far, the car also has a poor idle and has got worse from year one. No other error codes. Jaguar looked at the car 3 times over the years to find the poor idea and failed. It’s now at the point it needs fixing.
changed the maf checked for vacuum leak, used smoke and pressure No leaks detacted striped the manifold off and replaces the O rings around the pvc vacuum pipes all cleaned and reassembled cleared faults, disconnected he battery, after five mins both codes back
the car runs on LPG and petrol, I get the fault on both fuels, it runs 5% petrol while on gas.
Smoke tested again, nothing,
ok, main fold off again and bit the bullet and removed the Lower manifold as well, it’s very messy, but the seals are good.
All ideas welcome, still in a thousand pieces, so anything else to check.
Thankyou for looking
Geoff Here’s a odd video of the problem https://youtu.be/gVzRX0gxw0M
  • Welcome to Motor Vehicle Maintenance & Repair! – Pᴀᴜʟsᴛᴇʀ2 Apr 25 at 1:19
  • I would check that the valves for the variable induction system are working properly. Perhaps one is stuck open? – SteveRacer Apr 26 at 3:49
