This is my first time painting my car's plastic bumper and of course I made a mistake. I forgot to put on a layer of primer before the base coat. Now the base coat is already on, should I sand it off and start over or bite the bullet and continue with mid coat and clear coat?
Before applying the base coat, I sanded the entire bumper with 400 grit wet sandpaper. 60% of the area are down to bare plastic.
If I continue without the primer, how long will it last before peeling again?
  • When you sanded the bumper, was there evidence of a primer? If so you should prime it.
    Apr 22 '19 at 5:33
    Did you use or add plastic additive to the paint? Without the additive the paint will crack when the bumper flexes.
    – mikes
    Apr 22 '19 at 19:51
  • I used this paint. amazon.com/Harpy-Motors-2001-2001-DIAMOND-Guaranteed/dp/…
    – Ray Cheng
    Apr 23 '19 at 4:55
  • The base coat is dry, I'll try to flex it tomorrow see if it cracks.
    – Ray Cheng
    Apr 23 '19 at 4:56
