Well it’s a strange problem after taking the cheapest repair shop of the city where currently anything is not from me yet :
engine speed is unstable after 70℃ on gasoline and 55℃ on ʟᴘɢ mode and air conditioning switched off in both cases :
The ᴍɪʟ is always on on ᴏʙᴅ data but it gets light off on the dashboard after ignition is turned on (contradictory and very strange I know but this proves my question might be possible).
They are 2 problems which makes the ᴍɪʟ signaling :
P0328 (changing the knock sensor didn’t solve it) and
P0103 which is described asMass or air Flow High Input
(no idea of what it is and what’s the additional steps to diagnose and repair shops says “just asks Toyota repair services”). Clearing those problems along the ᴍɪʟ doesn’t help as they get back 3 seconds after turning ignition on.
Legal issues :
Because of the way the work of the previous repair shop was done, Toyota is refusing to repair the car and the previous repair shop definitely lack the knowledge for it (I insisted and they tried many times and failed and don’t know someone who can fix issues excepting Toyota).
But the car is imported from an other European country, in order to register it in my country, you need the foreign registration certificate. But Italy now requires to destroys registration certificate for being able to export cars. So the trick is I used the selling contract to establish a temporary registration certificate in my country (something possible only one time), I need it being valid for passing the Vehicle inspection test (it’s valid 6 months until 20 April). But the vehicle inspection test will fails if the ᴍɪʟ is on. A successful inspection test is required for registering the car definitely. The last deadline I could get for inspection is tomorrow at 11H15 GMT. So if the ᴍɪʟ is still on at that hour, the car will be in practice definitely banned from public roads even if the problem is fixed later.
What I want :
So with a good number of professionals being unable to fix the errors which sound to be Toyota specific, at that point, I have only one focus : get the ᴍɪʟ off during the inspection test tomorrow, even if it’s for 3 minutes and would work only on a cold engine.
I mean to disable the ᴍɪʟ without fixing the underlying problems. Legally, the ᴏʙᴅ can still report the error codes, but if it does, the ᴍɪʟ needs to be off on ᴏʙᴅ as it is on the dashboard.
I know this would result in the insurance being voided in case of an accident which is illegal, but it would get back to normal after fixing the underlying issues at a later date. The most important is to be able to register it before the last deadline as I don’t have the time to find someone or get the car repaired by Toyota (nor I know how to solve them myself).
If it can help, the ʟᴘɢ ᴇᴄᴜ is Stargas Pegasus 24, I talked to a Stargas installer, and he confirms that the ʟᴘɢ ᴇᴄᴜ is disabled when being on gasoline mode.
I also have a raw ᴏʙᴅ access : I mean I can send arbitrary sequences of bytes to the car.
