How do we call cars which 4WD is not always on, however you switch it on using separate gear shift transmission like the picture below.
Thanks in advance.
  • Welcome to Motor Vehicle Maintenance & Repair! – Pᴀᴜʟsᴛᴇʀ2 Apr 18 '19 at 23:18
    Today we'd call it "part-time" four wheel drive. "Back in the day", pickup trucks had what we called simply four-wheel-drive (4WD). It required manual locking of hubs (assuming they ever UNlocked - some really old 4WDs had always-connected hubs) and manual shifting of a transfer case into 4WD. Today's pickup trucks might have electrically operated shifting, but it's fundamentally part-time 4WD. – mike65535 Apr 19 '19 at 12:56
The type you are showing above is just Four Wheel Drive (4WD). It can be switched between ranges of the transfer case:
  • Two Wheel Drive (2WD or 2H on the gear shift above)
  • Four Wheel High - This is all four wheels getting power with the transfer case in the high range for greater speed. This is the same gear ratio as used for 2H.
  • Four Wheel Low - This is all four wheels getting power with the transfer case in the low ranger for greater torque and slower wheel speed.
With the type you have shown, this is a manual transfer case, shifted by a gear lever. Some older vehicles used to have two shifters sort of in a scissor pattern to do this, whereas now you'll only see one gear shift lever. There is also an automatic transfer case, which has a push button with servos in the transfer case to shift through to the different modes/ranges.
There is also, full-time 4WD, where you can switch between high and low range in the transfer case, but you cannot switch out into a 2WD configuration.
Then there is All Wheel Drive (AWD). This is technically 4WD, but there is only one transfer range, which is always for highway speeds. It is always engaged.
| improve this answer | |
  • @Error1004 what "below specs"? – Solar Mike Apr 19 '19 at 5:50
  • @SolarMike & Pᴀᴜʟsᴛᴇʀ2♦ thanks a lot. Clear and understandable. Could you please proposed cars the below specs: 4WD (NOT all time, driver should initiate them), automatic transmission & 1.5L to 2L? – Error 1004 Apr 19 '19 at 6:20
  • There are websites where you can do that search. Asking a shopping question is likely to get your question closed as "off-topic". – Solar Mike Apr 19 '19 at 6:23
  • @Solar Mike could you please introduce such websites? – Error 1004 Apr 19 '19 at 9:09
  • @Error1004 - We are not a site to give recommendations. I will say, however, to get where you want to be, I'd be looking at Subaru. – Pᴀᴜʟsᴛᴇʀ2 Apr 19 '19 at 15:30
