My 2007 Buick lacrosse was giving warm air when I turn on AC and I looked compressor and clutch wasn't turning so I thought I am low on refrigerant and went the shop did recharge and it was working just fine till I turned on the heater and turned off(to test) then turned on AC and the same problem again. What might be the problem?
I didn't use this car for 4-5 months and never turned on AC for like the last 6-7 months
8
  • Sounds like there could be a leak or seals have dried out - due to lack of use. get it checked - find out if it has lost fluid etc
    Apr 16, 2019 at 14:40
  • This happened right after they recharged the ac. After the shop I was going to work and wanted to test by turning the heater on and off then ac stopped working
    – Sami
    Apr 16, 2019 at 14:46
  • I did ac bypass but when I remove the clip ac stops working again. What can I do?
    – Sami
    Apr 17, 2019 at 0:10
  • Did you happen to hear a hissing noise inside the car while AC was still working?
    – Al_
    Apr 17, 2019 at 20:04
    That makes sense since the air compressor is working and giving cold air. Thank you again!! I don't think it will cost a lot to replace.
    – Sami
    Apr 18, 2019 at 14:11
