Disclaimer I know this is for a blower not an engine, but was not sure where exactly to pose the ?
I'm trying to assemble the fuel lines for the Ryobi BP42 two cycle blower, someone else took it apart so I did not see where all the lines ran before dis-assembly. But I found this image Fuel LInes
which my only question is....my carburetor is vertical where-as this one is horizontal....so that would mean that the fuel line would connect to the carburetor on the bottom (the curved insert on the carburetor). Is that correct?
Reason I am asking for clarification is that I did this set-up but when I was attaching the carburetor and the filter cover back to the blower itself the fuel line hose was just constantly dripping out the gas/oil mix from the carburetor. It was like the fluids were just running freely into the carburetor with no restrictions, so I wanted to verify my connections were accurate and if so, then ask where next to begin to troubleshoot this.
  • Your question is on-topic here at MVM&R. This is for a carb on an ICE, which means it fits in just peachy. Thanks for coming back and asking the question! Apr 13 '19 at 17:03
  • @Pᴀᴜʟsᴛᴇʀ2 - what is ICE? Apr 13 '19 at 17:11
  • ICE - Internal Combustion Engine Apr 13 '19 at 17:15
  • Ah - learn something new everyday. Thanks for the insight! Apr 13 '19 at 17:59
