Which Engine Control Module (ECM) Software version do I need to fix the Emissions Service Action 24DR issue for 2014 Volkswagen Passat?
Some details below:
The Emissions Service Action 24DR issue:
Current Engine Control Module (ECM) software may cause unintended system faults. If present, these faults could lead to illumination of the malfunction indicator light (MIL). If the MIL is on, the vehicle will not pass an emissions inspection.
Full recall letter:
When I go on https://www.vw.com/owners-recalls/ and enter my car's VIN, it doesn't specify the ECM version that fixes the 24DR issue:
ECU Update. VW ACTION CODE: 24DR
START DATE: 09-14-2018
DESCRIPTION: Current Engine Control Module (ECM) software may cause unintended system faults. If present, these faults could lead to illumination of the malfunction indicator light (MIL). If the MIL is on, the vehicle will not pass an emissions inspection.
REMEDY: Update the ECM software.
