What potential problems could occur if I tightened the passenger side motor mount by hand and didn't use a torque wrench? 09 Ford Focus SE sedan
1 Answer
None really as long as you have it sufficiently tight - if too loose it will vibrate looser and cause damage.
Many bolts do have a torque specified but they just get tightened - lug or wheel nuts are correctly tightened to the torque specified in most cases now. Any shop that uses a buzz gun I would avoid...
The drives shaft nut usually gets tightened to FT - as many places don’t have a torque wrench sufficiently large...
