When is a good time to charge a car battery after getting a new car?
This is to avoid a dead car battery.
Sign up to join this communityWhen is a good time to charge a car battery after getting a new car?
Assuming that everything is in good condition, you should rarely, if ever, need to charge the battery. As you are driving along, the alternator will charge the battery, and generally after about 5-10 miles of driving it should be fully charged again.
There are a few exceptions, such as if you frequently do very short journeys (especially in winter, when you also have lights, heaters etc on), or if the battery is reaching the end of it's life (5-8 years, depending on the local environment and usage patterns)
I'm too new to comment, but you can get a Automatic Battery Float Charger for pretty cheap (around 10 bucks) they're designed to not over charge and it will keep you from having to run your car to keep it charged. It also helps with the life of the battery.
