I recently experienced a major electrical shortage on my car, a Pontiac Sunfire 2003.
A 16 pins delphi connector started to burn up and I had to throw water at it. This connector seems to be powering the front lights as well as the horn and probably other things that I did not test.
Do I need to buy back a connector to replace it ? Or can I just put the wires together with tape and expect to have average results ?
They also seems to be pretty tight and depending on the damages, I might have to remove some cabling. What would be the common way to extend those cables to make them reach each other ? (I am thinking about extending them with cabling and other delphi connectors if necessary)
Thanks
