My 2000 Mitsubishi Montero Sport LS 4x4 has been making a nasty squeal when starting it and when I accelerate from a stop. I'm not sure exactly what is causing it. The water pump, timing belt, and serpentine belts were just replaced.
    Why not check the fan belt and tighten if necessary
    – Autistic
    Apr 5, 2019 at 10:57
  • As Autistic wrote - always suspect the last thing touched.
    – mike65535
    Apr 5, 2019 at 12:54
  • Welcome to Motor Vehicle Maintenance & Repair! Apr 5, 2019 at 19:47
