It all went together well but now it vibrates when accelerating. Is sur Tack a best replacement joint? Wondering if there is a better manufacturer.
1Did you make sure that all the nuts were correctly tightened? Suspension, wheel etc? – Solar Mike Mar 26 '19 at 15:58
yes all was tight even replace drive shaft – Bill Billncar Mar 26 '19 at 16:00
Thinking it was a bad part just wondering if someone thinks there is a better brand ,just thinking if their were out of balance their would vibrate all the time? – Bill Billncar Mar 26 '19 at 16:24
Never heard of them (probably because you are on a different continent..), but they could be good quality but a bad one always gets through... – Solar Mike Mar 26 '19 at 16:34
I think what Solar Mike was asking is, was everything torqued correctly? It doesn't matter if everything is tight if it wasn't torqued to the proper spec. You can cause damage to the parts by not having torqued them to spec, which may in turn cause vibration. – Pᴀᴜʟsᴛᴇʀ2♦ Mar 26 '19 at 17:03
